URL Whitelist for XI Installation / Upgrade
rajasegar
Post by rajasegar »
Internet access to the servers has been restricted to approved sites only.
Now the upgrade does not work anymore.
I need the list of all the hosts the installer accesses during installation or upgrade.
Where can I get this list?
Thanks.
5 x Nagios 5.6.9 Enterprise Edition
RHEL 6 & 7
rrdcached & ramdisk optimisation
benjaminsmith
Re: URL Whitelist for XI Installation / Upgrade
Post by benjaminsmith »
Hello @rajasegar,
Below is a link to the offline installation instructions. Please note the instructions are not for an offline upgrade for a system installed with network access. I would recommend doing a offline installation on another server or VM, and then migrate your data.
Installing Nagios XI in an Offline Environment
Backing Up and Restoring Nagios XI
The Nagios XI license allows for 3 installations, production, test and backup, so you can set this up on a test system before migrating the production server to an offline server.
Nagios XI - License Entitlements
Let us know if you have any questions.
rajasegar
Post by rajasegar »
benjaminsmith wrote:Hello @rajasegar,
I don't need offline installation. I just need to whitelist the sites the installer might access.
Please update if there is a way to figure this out.
RHEL 6 & 7
On our site the hosts would be:
repo.nagios.com
assets.nagios.com
api.nagios.com
However, many packages will be installed via repositories, but as long as you already have your normal reposttories whitelisted the above should be all.
rajasegar
Post by rajasegar »
scottwilkerson wrote:On our site the hosts would be:
repo.nagios.com
assets.nagios.com
api.nagios.com
Thanks will try it out
RHEL 6 & 7
Let is know if we can be of further assistance
