Problem update NagiosXI via console
eSailVite
Post by eSailVite »
I have tried update my nagios xi and not working... All the time show me "Update in progress. Please wait. Update may take a few minutes.
Re: Problem update NagiosXI via console
This can happen on some systems due to permissions issues.
Can I have you run the manual upgrade following the procedure in this document
https://assets.nagios.com/downloads/nag ... ctions.pdf
FLCUISIT
Post by FLCUISIT »
I am having a similar issue. I ended up doing a manual update at the console, and that completed successfully. However, the GUI still shows that an update is in progress. Is there a way to clear that message out and validate that it has been updated?
# grep xiver /usr/local/nagiosxi/var/xi-sys.cfg
xiver='5.6.7'
FLCUISIT wrote:I am having a similar issue. I ended up doing a manual update at the console, and that completed successfully. However, the GUI still shows that an update is in progress. Is there a way to clear that message out and validate that it has been updated?
xiver='5.6.7'
You should be able to click the "Go back" button on that page
FLCUISIT
Post by FLCUISIT »
What "Go Back" button are you mentioning? I assume you are not talking the browser back button, nor is there one on the page.
Sorry, I was getting ahead of myself, here is a procedure to fix the display
https://support.nagios.com/kb/article/n ... e-851.html
FLCUISIT
Post by FLCUISIT »
Perfect - thanks for the help.
FLCUISIT wrote:Perfect - thanks for the help.
No problem
Locking thread
