I'll start by saying that I'm totally new to CentOS and Nagios. Now to the issue, I'm attempting to manually install Nagios XI on CentOS 6.2 but I keep receiving an Installation Error:
[root@localhost ~]# cd /tmp/nagiosxi
[root@localhost nagiosxi]# ./fullinstall
Nagios XI Full Installer
This script will do a complete install of Nagios XI by executing all necessary
sub-scripts.
IMPORTANT: This script should only be used on a 'clean' install of CentOS
or RedHat. Do NOT use this on a system that has been tasked with other
purposes or has an existing install of Nagios Core. To create such a clean
install you should have selected ONLY the 'Base' package in the OS installer.
Do you want to continue? [Y/n] y
Proceeding with installation...
Checking MySQL credentials...
MySQL not yet installed - that's okay.
Running './0-yum'...
Configuring Yum...
centos-release-6-2.el6.centos.7.i686
rpmforge-release RPM installed OK
Enabling EPEL repo...
RESULT=1
INSTALLATION ERROR!
in your communications with Nagios XI technical support.
The script that failed was: './0-yum'
[root@localhost nagiosxi]# ^C
Nagios XI Installation Error on CentOS 6.2
GreenMonster
