After some manual configuration this is our current look of Nagios Map. However I would like the hosts to have some spaceing between them automatically. As you can see the names of the hosts can not be read. I have unsucessfully tried some solutions (I get errors, or I dont know how to do it), see below some of my problems. Best would be to use the patch automatically, but nagiosmap.pl sounds like a almost ok solution.
Do you know any solutions that do this?
/Nick
nagiosmap.pl
No protocol specified
couldn't connect to display ":0" at /usr/lib/perl5/site_perl/5.12.1/i586-linux-thread-multi/Tk/MainWindow.pm line 53.
MainWindow->new(-title,NagiosMap v3.2) at ./nagiosmap.pl line 96
Patch for Nagios 3.0a5 - increase radius of circular layout
Dont know how to install. I guess I need to recompile all, but Im afraid of doing it without an instruction.
Nagvis
How to import the nagiosmap so that I can move the nodes/hosts?
Alternatives
Do you have any alternatives?
OS: Linux 2.6.34.10-0.6-default i686
System: openSUSE 11.3 (i586)
KDE: 4.4.4 (KDE 4.4.4) "release 3"
Nagios® Core™
Version 3.2.1
Nagios Map
Re: Nagios Map
I'm not familiar with Nagios Map, but I can recommend NagVis as an alternative. I see you mentioned it in your post, but I didn't really understand your issue with it.
