I' am running NagiosXI in VMware in test environment where i've added almost all servers from my data center successfully. Taking into consideration that for SMS alerting i cannot directly connect my modem / SMS device via serial port directly in this case, i want to move my configuration to a separate physical hardware.
I've installed NagiosXI manually on Centos 5.4 conveniently (thanks God!!!) on a separate physical machine. All i want is to move my configuration from Test VMware machine to this new physical hardware (Just to avoid re-doing all the tasks of adding servers/services again for 25+ servers)
I also want to know if it is going to effect licensing and support provided. Though i've decided to buy the license after getting the above things clear.
Plz help me for the above and consider the fact that i am new to NagiosXI but still loves my old nagios 2.6 that i was using earlier
