MRTG Config
MRTG Config
I want to monitor my switch using MRTG, but something is not well configured, I followed some of the topics for the error that I have which is : "check_mrtgtraf: Unable to open MRTG log file "
knowing that /var/www/mrtg contains some interface logs
I read in some forums that /var/lib/mrtg/ must contain the log file that nagios reads, but in my case it contains only cfg files
can you guys help me through this config
benjaminsmith
Re: MRTG Config
Hello @koumni,
Have you checked permissions on that directory to make sure it is writable/accessible by the nagios account on the server? Please post the output to the following commands.
ls -ld /var/lib/mrtg
ls -l /var/lib/mrtg
Re: MRTG Config
I would also look at the /etc/mrtg/mrtg.cfg file which will have information about the log location and format.
Re: MRTG Config
benjaminsmith wrote:Hello @koumni,
ls -ld /var/lib/mrtg ls -l /var/lib/mrtg
nagios@sn-srv-nagios:~$ ls -ld /var/lib/mrtg
drwxrwxrwx 2 nagios nagios 12288 Oct 27 15:04 /var/lib/mrtg- Attachments
ls-l.txt- ls -l /var/lib/mrtg
- (9.63 KiB) Downloaded 309 times
Re: MRTG Config
Here it iscdienger wrote:I would also look at the /etc/mrtg/mrtg.cfg file which will have information about the log location and format.
mrtg.cfg- (39.82 KiB) Downloaded 342 times
Re: MRTG Config
Can you post the Nagios configuration you are using for the Port 1 Bandwidth Usage check?
Did you setup a cron job to run the MRTG application which gathers the Bandwidth information the check_mrtgtraf plugin needs to calculate the bandwidth?
Check this link for instructions for MRTG.
https://oss.oetiker.ch/mrtg/doc/mrtg-unix-guide.en.html
If you run the following as root, it will run the MRTG application in debug mode which you can use to troubleshoot the MRTG application.
Re: MRTG Config
This is the service conftgriep wrote:Can you post the Nagios configuration you are using for the Port 1 Bandwidth Usage check?
# Monitor bandwidth via MRTG logs
use generic-service ; Inherit values from a template
host_name HP-DATA-CORE
service_description Port 1 Bandwidth Usage
check_command check_local_mrtgtraf!/var/lib/mrtg/172.20.232.1_1.log!AVG!1000000,1000000!5000000,5000000!10
}Code: Select all
command_name check_local_mrtgtraf
command_line $USER1$/check_mrtgtraf -F $ARG1$ -a $ARG2$ -w $ARG3$ -c $ARG4$ -e $ARG5$
}Code: Select all
*/5 * * * * /usr/bin/env LANG=C /usr/bin/mrtg /etc/mrtg/mymrtg.cfg –logging /var/log/mrtg.log
*/5 * * * * /usr/bin/env LANG=C /usr/bin/mrtg /etc/httpd/conf/mrtg.cfg --logging /var/log/mrtg.log
Re: MRTG Config
Your Nagios check is setup to use this file to gather the Bandwidth but is does not exist on your system.
The closest file I saw in the ls output is this named this.
Is this the MRTG log file you should be using for that check?
If not, you will have to re-run the cfgmaker command to create a new entry for that interface and then the plugin will find the file.
Else, edit the check and remove the _1 from the filename.
/var/lib/mrtg/172.20.232.1_1.logCode: Select all
/var/lib/mrtg/172.20.232.1.logIf not, you will have to re-run the cfgmaker command to create a new entry for that interface and then the plugin will find the file.
