Check host without using ping
t3dus
Post by t3dus »
I know this probably has been asked before but I can't find the answer.
We have moved some websites to Azure and they don't allow for host checks via ping. So how can I change our external nagios server to check via http instead?
I found this guide for NagiosXI which works beautifully for our internal nagiosxi server but not sure how to do the same for nagios core. https://assets.nagios.com/downloads/nag ... _In_XI.pdf
t3dus
Re: Check host without using ping
Post by t3dus »
You can close this. I just answered my own question
https://support.nagios.com/forum/viewto ... =7&t=32202
t3dus wrote:You can close this. I just answered my own question
Great!
Locking thread
