Unable to open Nagios Core console on setup created on SLES
rajshekar_p
Post by rajshekar_p »
Hi Team,
I am hitting with below issue when i try to open Nagios Core console. There is no issue with Apache service.
Access forbidden!
You don't have permission to access the requested directory. There is either no index document or the directory is read-protected.
If you think this is a server error, please contact the webmaster.
Error 403
100.100.29.3
Apache
Below are the setup details:
Nagios Core version - 4.4.5
OS details - SLES 15 SP1
Can yo u please help on this.
Thanks & Regards,
Rajshekar P
Re: Unable to open Nagios Core console on setup created on S
Can you share the nagios.conf from the apache config directory?
rajshekar_p
Please find attached nagios.cof file.
Thanks & Regards,
Rajshekar P
nagios.conf
nagios.conf file
(1.64 KiB) Downloaded 352 times
And you did restart Apache after the installation correct?
Do you see errors in the apache error log?
what are the permissions here
ls -al /usr/local/nagios/share
rajshekar_p
Please find attached "error_log" and "ls -al /usr/local/nagios/share" output.
I see few failures in "error"log".
Thanks & Regards,
Rajshekar P
error_log.txt
error_log
(1.42 KiB) Downloaded 156 times
"share" directory permissions
Ok, you are getting
No matching DirectoryIndex (index.html,index.html.var)
This leads me to believe php isn't installed
Did you install the prerequisites here?
https://support.nagios.com/kb/article/n ... .html#SUSE
rajshekar_p
I installed PHP. And restarted "apache2" and "nagios" service.
PHP version - 7.4.0
Attached "error_log" post PHP installation.
Thanks & Regards,
Rajshekar P
error_log-Post_PHP_Installation.txt
error_log-Post PHP Installation
(1.43 KiB) Downloaded 137 times
You also need to run these
sudo /usr/sbin/a2enmod rewrite
sudo /usr/sbin/a2enmod cgi
sudo /usr/sbin/a2enmod version
sudo /usr/sbin/a2enmod php7
sudo systemctl enable apache2.service
rajshekar_p
Thanks for the quick help. post installation of "php7" and "apache2-mod_php7", issue is resolved.
Regards,
Rajshekar P
rajshekar_p wrote:Hi,
Regards,
Rajshekar P
Great!
Locking thread
