supportability query
IT-OPS-SYS
Post by IT-OPS-SYS »
Does Nagios Xi supports the monitoring of the Windows Server 2016/2019 Server Core?
mbellerue
Re: supportability query
Post by mbellerue »
As long as there is some way to connect to the server, and pull down the status of something that you want to monitor, we can monitor it. Are you able to install the NCPA agent to your servers? That would probably still be the best way to monitor the server, regardless of whether the full GUI is installed or not.
IT-OPS-SYS
do we support installation of ncpa agent on the non-GUI windows server?
mbellerue
Post by mbellerue »
To my knowledge we don't do indepth testing with Windows Server Core. But I did just fire up a Windows Server 2016 Core VM, and was able to install NCPA and start running checks against the server. There isn't a silent option for the installer, so it does have to be installed at the console of your VM or physical server. But once you execute ncpa-2.2.0.exe in the cmd or Powershell window, it has no problems displaying the window for the installation.
IT-OPS-SYS
I can try on my system and will let you know the results.
thanks again
mbellerue
Post by mbellerue »
Perfect, we will keep this thread open and wait to hear back.
