Team,
Few log files under /usr/local/nagiosxi/var have grown as big as 9GB.
I would like to know what is significance of these files and can it be rotated after certain intervals. Additionally, what should be the retention policy for these files?
- Box293
- Too Basu
Re: log files under /usr/local/nagiosxi/var
These log files are used for reporting and the event log feature of Nagios. Deleting these files means that this data won't be available for reports, hence retain them for as long as you want to run reports against them.
