while running the top I see that there are couple fo processes which are for httpd process from the apache user
/usr/sbin/httpd -DFOREGROUND
may i know wat this process is and how can we get rid of these process consuming the high cpu and memory.
nagios performance
IT-OPS-SYS
nagios performance
Re: nagios performance
httpd is the apache web server which run the UI for you to access the web interface for Nagios XI.
The more people you have using the web UI, reports running and API calls, etc., the higher the CPU and memory utilization will be for these process.
This is a required component of Nagios XI and the only way to reduce this would be to have less people using the interface.
IT-OPS-SYS
got it. thanks for your explanation
No problemIT-OPS-SYS wrote:got it. thanks for your explanation
Locking thread
