How to configure NRDP to use a different port
MrPippin
Post by MrPippin »
As is, NRDP will use the same web server port access as your web based Nagios Core dashboard.
I don't see any documentation in the NRDP instructions for how to setup NRDP to use another port for NRDP access.
Are there any instructions available to have NRDP use a different port than the the Nagios Core dashboard? And to have it also be SSL?
Re: How to configure NRDP to use a different port
Post by Box293 »
I don't have instructions for using a different port.
However you can see that /etc/httpd/conf.d/nrdp.conf is presenting /nrdp as an alias of Apache's default web page.
As for TLS, please check this documentation:
https://support.nagios.com/kb/article/n ... s-603.html
