Going through the web interface.
XI 5.5.10 on RHEL 6.10
Clicked check for updates then update.
It's been sitting at "Update in progress" for 15 minutes now.
Update hangs on "Update in progress"
Re: Update hangs on "Update in progress"
Let's run the manual upgrade procedure if this hasn't completed
https://assets.nagios.com/downloads/nag ... ctions.pdf
If this goes through successfully you can reset the status following this
https://support.nagios.com/kb/article/n ... e-851.html
It never finished updating so shortly before your post I rolled back to the snap I took before starting.
I'll go through the manual procedure you linked to and post the results.
Sounds good!teh0015 wrote:It never finished updating so shortly before your post I rolled back to the snap I took before starting.
That ran without a hitch and upgraded to 5.6.14
Thank you.
Now onto the ldap issue (I'll start another thread)
Thank you.
Great!teh0015 wrote:That ran without a hitch and upgraded to 5.6.14
Thank you.
Locking thread
