we are getting 3 errors after upgrade to 5.7
Error 1:
SQL Error [nagiosxi] : You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'WHERE user_id = 1' at line 3
Error 2:
Your license needs to be re-activate in order to access certain features of Nagios XI. Activate your license now.
Error 3:
ndo2db unrecognized service (while trying to repair database)
We have tried repairing the database but that doesn't help. Output of database repair below.
Error post 5.7 upgrade
Re: Error post 5.7 upgrade
Your upgrade doesn't seem to have finished properly, can you post your upgrade.log from inside the nagiosxi directory that you upgraded from? Typically that's /tmp/nagiosxi.
pls see attached
looking at the logs.
the upgrade to 5.7 was not successful, and we're not sure how to revert back to the previous working version. or how to get the upgrade to v5.7 working...
Have you backed up your Nagios XI system prior to attempting the upgrade to XI 5.7.0 as described in our official documentation?
If you have, you could restore your system, but following the steps, outlined in the document listed above.
Having said that, I would recommend that you rerun the upgrade script.
If it fails again, post the new (updated) upgrade.log on the forum. Thanks!
cd /tmp/nagiosxi
./upgradeBe sure to check out our Knowledgebase for helpful articles and solutions!
I see you opened a ticket as well.
I'm going to close this thread and reference the thread in the ticket.
If you could, pleas add the above to the ticket
Thanks!
Thanks!
