graphs are not showing
pratap.singh
Post by pratap.singh »
Hi
all of sudden Nagios XI is not showing any graphs for switch interface, showing only for ping
I don't know if this is related to below error when I tried to start npcd service
[07-07-2020 16:54:58] NPCD: Caught Termination Signal - Hasta la vista... baby
[07-07-2020 16:54:58] NPCD: npcd Daemon (0.4.14) started with PID=21905
[07-07-2020 16:54:58] NPCD: Please have a look at 'npcd -V' to get license information
[07-07-2020 16:54:58] NPCD: HINT: load_threshold is enabled - ('10.000000')
[07-07-2020 17:05:47] NPCD: Caught Termination Signal - Hasta la vista... baby
[07-07-2020 17:05:47] NPCD: npcd Daemon (0.4.14) started with PID=46444
[07-07-2020 17:05:47] NPCD: Please have a look at 'npcd -V' to get license information
[07-07-2020 17:05:47] NPCD: HINT: load_threshold is enabled - ('10.000000')
I moved to xi in Dec 2019 and have a standard license
let me know how to resolve this
Pratap Singh
benjaminsmith
Re: graphs are not showing
Post by benjaminsmith »
Hi Pratap,
Welcome to the Nagios Support Forum! Looking over the issue here, if the npcd daemon is not running that should affect the other graphs as well. Can you verify if this is the case?
It may be crashing due to spooled up files, so please follow the steps in the guide below under Count The Amount Of Spooled Files to check this and delete the files if necessary.
Nagios XI - Performance Graph Problems
If that does not resolve the issue, increase the logging verbosity as directed in the guide, let the system run for a while and the send us a fresh system profile so we can review the logs and settings. Thanks, Benjamin
To send us your system profile.
Login to the Nagios XI GUI using a web browser.
Save the profile.zip file and share in a private message or upload it to the post/ticket, and then reply to this post to bring it up in the queue.
