Hi
After applying a configuration the Home Dashboard take a long while to report correctly
I have just noticed this after upgrading to version 5.7.1
Sometimes it can take 4 - 5 clicks of the home screen before the Dashboard shows correctly
I have attached screenshots
Is this normal for this version ?
Home Dashboards takes a long time to refresh correctly
benjaminsmith
Re: Home Dashboards takes a long time to refresh correctly
Hi @mccrakem,
A couple suggestions and then let me know if you see any improvement. First, I would recommend upgrading to 5.7.2 as there are some important bug fixes in this release. Be sure to take a backup or snapshot before upgrading.
Upgrading Nagios XI
Secondly, let's optimize the PHP settings in this instance. The steps are shown in the kb article below.
Nagios XI - Optimizing The PHP Settings File
If you're still seeing the issue, send us your system profile and we'll check the logs for any issues. Thanks, Benjamin
To send us your system profile.
Login to the Nagios XI GUI using a web browser.
Save the profile.zip file and share in a private message or upload it to the post/ticket, and then reply to this post to bring it up in the queue.
Upgrading Nagios XI
Hi Ben
editing and increasing the /max_input_vars setting looks like it has really improved the performance of the application
Thanks for your help with this, you can consider this closed
benjaminsmith
Excellent!Thanks for your help with this, you can consider this closed
Have a great weekend.
Benjmain
