When I verify test syntax from the CCM Services GUI I noticed this.
Sometimes the close button floats and obscures text I'd like to see. This issue varies with browser zoom settings. (Chrome)
Steve B
Floating close button
SteveBeauchemin
XI 5.7.3 / Core 4.4.6 / NagVis 1.9.8 / LiveStatus 1.5.0p11 / RRDCached 1.7.0 / Redis 3.2.8 /
SNMPTT / Gearman 0.33-7 / Mod_Gearman 3.0.7 / NLS 2.0.8 / NNA 2.3.1 /
NSClient 0.5.0 / NRPE Solaris 3.2.1 Linux 3.2.1 HPUX 3.2.1
Re: Floating close button
Are you in full screen mode (using all screen real-estate) or in windowed mode? (I'm referring to the browser window sizing)
What OS/Version is it running?
What is your screen resolution?
I'm going to lab it up and see if I'm able to replicate it.
SteveBeauchemin
Not full screen mode
1920 x 1200
Windows 10 (Ver 1809)
1920 x 1200
I've submitted a bug report for this with a link back to this thread so the developers can fix it, I was able to replicate it on mine as well:
NEW TASK ID 15353 created - Nagios XI Bug Report: XI - CCM - Run Check Command Close button hiding text
SteveBeauchemin
As long as I'm not the only one with this issue I'm happy. I hate being the crazy one.
Please close.
Steve B
Please close.
Steve B
