[Feature] enable and disable notification by schedule
mansonli
Post by mansonli »
Is the function of enabling and disabling notification by schedule on host and/or service not yet available even on latest XI release, i.e. 5.7.4? For example, It's required to enable notification when a host and its service will go live at a schedule date and time. If it's not yet implemented, pls pass this request to feature request list for development team to consider to add in future release.
benjaminsmith
Re: [Feature] enable and disable notification by schedule
Post by benjaminsmith »
I can certainly put in a feature request on your behalf. In the meantime, there are a couple of workarounds that might be an option for you. One, is the use of Scheduled Downtime. This will suppress notifications during a set period.
https://support.nagios.com/kb/article/n ... e-544.html
The other option is to set the notification period as required. The timeperiod settings are quite flexible, check out the examples on the following page.
https://assets.nagios.com/downloads/nag ... timeperiod
Appreciate your input. Let me know if you need anything else.
Benjamin
