Downtime
progressive.nagiosXI
Downtime
Post by progressive.nagiosXI »
Hi Support team,
we put recurring downtime for the host-group but maintenance not activated on daily basis as per scheduled downtime.
Please check snap and help
benjaminsmith
Re: Downtime
Post by benjaminsmith »
Let's make sure the cron service is running (if that's stopped it's not going to start the job).
systemctl status crond
If that's running and it's still not working, please post a tail output of the cron log and PM the system profile to further troubleshoot.
tail -n 25 /var/log/cron
Thanks, Benjamin
To send us your system profile.
Login to the Nagios XI GUI using a web browser.
Re: Downtime
Hi Benjamin,
details shared in PM.
benjaminsmith
Re: Downtime
Got the profile, thanks! I located this downtime entry in the configurations, but I'm not seeing any direct errors in the logs. There's a special log for recurring downtime, can you upload or PM that as well.
/usr/local/nagiosxi/var/recurringdowntime.log
Let's also verify the permissions on the configuration file.
 ls -l /usr/local/nagios/etc/recurringdowntime.cfg
--Benjamin
Re: Downtime
Hi Benjamin,
Please share the update on the below issue, we shared the required details in PM(10Dec.)
If any other detail require please let us know
Re: Downtime
Sent: Thu Dec 10, 2020 12:34 pm
To: benjaminsmith
benjaminsmith
Re: Downtime
Thanks for that log, it looks like the downtime isn't being scheduled since it's not set to run in December.
	months_of_year		,jan,feb,mar,apr
	svcalso			1
	schedule_type		hostgroup
	hostgroup_name		xxxxs_Brxxxxx_Server
Try editing the settings for this downtime operating adding the other months and let me know if it starts scheduling after that. To adjust the settings go to Home > Incident Management > Recurring Downtime
--Benjamin
