License falsely expiring and update checks failing
gormank
Post by gormank »
The update check in admin shows failed and even though the contract has been renewed, it shows as expiring. If the update check succeeds will the support agreement date update as well? Or do I need to enter the license keys and enterprise keys every year (seems unlikely)?
The proxy settings are correct and I see the proxy port is open.
What is the URL for the upgrade check? Maybe I need to change the whitelist in the proxy config...
benjaminsmith
Re: License falsely expiring and update checks failing
Post by benjaminsmith »
Hi @gormank,
The license server is at:
api.nagios.com
I would verify that the system can connect to and resolve that domain. Let me know if there are any connection issues.
You shouldn't need to change the keys, but if you're still having trouble please reach out to [email protected]. Your customer success manager's name is Ryan.
Regards,
Benjamin
gormank
Post by gormank »
I added api.nagios.com to the whitelist in the proxy and that fixed both the available updates and license checks so we're all set. Close this anytime.
Thanks!
benjaminsmith
Sounds good. We'll close this out.
Have a great weekend!
