Hello ,
I have a question .
I have to monitor IIS Active Requests counter on a windows server . And I heard from someone that it could be possible through Perfmon protocol .
Could you explain to me what exactly is this perfmon plugin and protocol .
Perfmon plugin
benjaminsmith
Re: Perfmon plugin
Yep, you can monitor performance counters in Nagios XI. Have you installed an agent like NCPA on this server? That would be my recommended approach here as it has the ability to monitor windows counters.
A few docs with more details.
Nagios XI - Monitoring Performance Counters in Nagios Using NCPA
https://www.nagios.org/ncpa/help.php#ap ... wscounters
Let me know if you think that approach is going to work for you.
Reference:
Performance Counters for Monitoring IIS
Reference:
Re: Perfmon plugin
Thanks .
You can close the ticket .
Re: Perfmon plugin
Locking threaddeek wrote:Thanks .
