Monitoring AAD, M365, Azure
jenglish
Post by jenglish »
I'm trying to find a good solution with using Nagios to determine when M365 is down/having issues, etc.
My thoughts are:
- some type of M365 login test via Nagios
- scraping the text of something like MS status page
Reference:
https://www.bleepingcomputer.com/news/m ... ge-online/
​An Azure Active Directory outage is preventing users from logging into Microsoft 365, Microsoft Teams, Exchange Online, Forms, Xbox Live, and Yammer.
vtrac
Re: Monitoring AAD, M365, Azure
Post by vtrac »
Nagios® Exchange is the central place where you'll find all types of Nagios projects - plugins, addons, documentation, extensions, and more. This site is designed for the Nagios Community to share its Nagios creations.
https://exchange.nagios.org/
Here's the one I found for Windows Azure Monitor:
https://exchange.nagios.org/directory/P ... or/details
Here are couple Nagios's wizards under Nagios XI GUI > Configure > Configuration Wizards you can check out:
Microsoft Azure Cloud
Microsoft/Office 365
Monitoring Office 365 Subscription Services (HowTo):
https://support.nagios.com/kb/article/m ... s-881.html
Regards,
Vinh
jenglish
Post by jenglish »
Thanks, @vtrac
Those Wizards do not appear in my Configuration Wizards panel:
I'm running 5.8.1 - I should have this Wizard already available to me, no?
(PRO-BOY|jme@boyvlp-netopsmon1 bin)$ grep full /usr/local/nagiosxi/var/xiversion | cut -d = -f 2
5.8.1
vtrac
Post by vtrac »
Looks like you do not have the "MS/Office 365", this is new for 5.8.x. You might be missing it during the upgrade process.
I have attached the "microsoft_365.tar" file.
Please download the "microsoft_365.tar" file and put it under the directory below
/usr/local/nagiosxi/html/includes/configwizards
Now run:
cd /usr/local/nagiosxi/html/includes/configwizards
tar -xvpf microsoft_365.tar
You should now see "Microsoft Office 365" wizard after you refresh the page.
Regards,
Vinh
jenglish
Post by jenglish »
That worked. Thank you so much.
vtrac
Post by vtrac »
Great!! .... Please let me know if I can close this post/ticket?
Regards,
Vinh
jenglish
Post by jenglish »
Yes. All good. Thanks again.
jenglish wrote:Yes. All good. Thanks again.
Closing case
