GOod afternoon,
I was working with Support last week on a continued DB issue, I have since upped the connectivity of the DB but today I have stopped receiving alerts and the DB maint light is now red. I have tried running the clean up with no luck.
Any thoughts?
Nagios DB maint status red
benjaminsmith
Re: Nagios DB maint status red
If you're not getting alerts, then the nagios process must have stopped. Try restarting it by running the following command and if it fails please post any error in the thread.
Also, since you are having db issues, run the repair script as root from the CLI.
The database maintenance script runs on a cron job, make sure the cron service is up and running.
If you continue to have issues, please send us a current system profile. If the database is offloaded, please attach the log from the remote host as it will not be in the profile.
To send us your system profile.
Login to the Nagios XI GUI using a web browser.
Thanks, Benjamin
### Log Locations and Descriptions
Nagios XI Log Files and Descriptions
systemctl restart nagios
/usr/local/nagiosxi/scripts/repair_databases.sh
systemctl status crond
Thanks, Benjamin
I have performed those commands and repaired the DB. Still not seeing any alerts.
I was unable to use the gui to download a profile so I used the command to get one downloaded.
Moderator's Note: The profile has been shared with the support team but has been removed from the public forum.
benjaminsmith
Hi @jsalsbury,
Thanks for attaching the system profile. Did the maintenance status go green after running the repair script? If not, please try to re-boot the server.
I'm still seeing connection issues in the database log.
Reference: Nagios XI - MySQL/MariaDB - Max Connections
The system profile is running, so I'm surprised that you are not seeing any notifications, the nagios log is showing incoming check results. Try to send a custom notification from a host or service, and let me know if that is successful. This can be done by finding a host from the home page under details > host status, selecting the advanced tab, and then selecting the Send Custom Notification option.
Also from the home tab, select Force and Immediate Check, and let me know if the Last Check and Next Check update in the GUI.
If you haven't done so already, please run the XI Server Wizard, so we can monitor the system processes.
Also, the following host is timing out, so it is likely down or unreachable.
--Benjamin
What is the output to the following queries?210419 17:33:09 [Warning] Could not increase number of max_open_files to more than 1024 (request: 1075)
mysql -uroot -pnagiosxi -e "show variables like 'max_connections';"
mysql -uroot -pnagiosxi -e "show global status like 'Max_used_connections';"
pepxxxxx23.corp.pep.pvt
