Notifications without changing the service status
meolic
Post by meolic »
We have a service in NagiosXI which is implemented via bash script. The script produces exit code 0, 1, or 2. It is called every minute. We want to get a notification if the bash script find something wrong. This works OK for the first time, the script just set exit status 2. But, in some cases, the situation in the observed system get worse and we want to send another notification to the operators. We have already set status to 2 (CRITICAL), so there is not much we can do. What is the best way to solve this?
BTW, we have a hack. When we want an additional notification, we change status to 1 (WARNING) even if the situation got worse. Notification is sent becasue the status has changed. For additional notifications (yes, there can be more) we simply alternate between statuses 1 and 2. But this is not very nice solution. It would be, if the service could be hidden from GUI, so that the operator is not seeing the color (he/she does not like that WARNING may denote a worse situation than CRITICAL).
ssax
Dreams In Code
Re: Notifications without changing the service status
Post by ssax »
You could enable is_volatile on the service:
https://assets.nagios.com/downloads/nag ... vices.html
meolic
Post by meolic »
ssax wrote:You could enable is_volatile on the service:
Thank you for the suggestion. But, we do not want that the notification is sent everytime the service is checked - it is checked every minute! The notification must be sent only if the bash script decided that the notification is needed.
meolic
Post by meolic »
If is_volatile could be dynamically set and reset from the bash script... but this seems to be a wrong approach anyway.
The passive checks may be the right directon. But, we do not have the experiences with them. Can anyone post a short receipt how the requested behaviour could be implemented with the help of passive checks?
ssax
Dreams In Code
Post by ssax »
Does that check currently run on the XI server or is it being called on another system?
Given that the notification functionality will not meet your needs in this case I would enable is_volatile on the service and then set it up as a passive check (just run it on a cron job) and adjust the bash script to only submit the results when you want it to. The reason I'm not recommending an agent for this (like I usually would to run passive checks) is because the agents will ALWAYS send the results, you can't stop it from sending the results (good or bad). With a cron job you would control whether a result is sent or not.
If the script is not on the XI server you could:
Setup NRDP to receive passive results:
https://assets.nagios.com/downloads/nrd ... erview.pdf
Then have your bash script submit them:
https://support.nagios.com/kb/article/n ... t-599.html
If the script is on the XI server you can either do the NRDP process above or this:
https://assets.nagios.com/downloads/nag ... and_id=114
As an alternative you can have your bash script do this to send a notification:
https://assets.nagios.com/downloads/nagioscore/docs/externalcmds/cmdinfo.php?command_id=135
meolic
Post by meolic »
The bash script is located on Nagios XI server in /usr/local/nagios/libexec/scripts. Thus, your answer is applicable. Thank you.
ssax
Dreams In Code
Post by ssax »
Great, let us know if you have any related questions.
