Upgrading from 5.6.7 to 5.8.3 on CentOS 6
TBT
Post by TBT »
In an effort to migrate off CentOS 6 (EOL) to Debian 10, we're planning to upgrade XI from 5.6.7 to 5.8.3 prior to migration.
Will upgrading from 5.6.7 to 5.8.3 on CentOS 6 still succeed or must we upgrade to a lesser XI release?
Nagios XI 2024R2.2.1 (8 Servers)
Nagios Fusion 2024R1.0.2
vtrac
Re: Upgrading from 5.6.7 to 5.8.3 on CentOS 6
Post by vtrac »
How are you doing?
I am very sorry but you can only upgrade to Nagios XI 5.7.5 on CentOS 6.
Here's the KB for upgrade Nagios XI:
https://assets.nagios.com/downloads/nag ... ctions.pdf
As to doing the migration from CentOS to Debian, since you're changing OS versions, please remember run the restore_repair script from the backup/restore guide below after restored:
Best Regards,
Vinh
TBT
Post by TBT »
Thanks for the confirmation. I also assume once 5.7.x is migrated over to the Debian server we'll then have an upgrade path from 5.7 to 5.8, correct?
vtrac
Post by vtrac »
Hope your day is going well.
Yes, once 5.7.x is migrated over to the Debian server then you can upgrade from 5.7.x to 5.8.3.
Here's process for migration, then upgrade to latest XI.
The XI backup/restore process makes this pretty easy.
The process is this:
- Spin up new Debian server
- Install the exact same version of XI that the old server has on the new server, no need to configure it, just install it (do not try to restore over different versions you will cause issues)
https://assets.nagios.com/downloads/nag ... -Linux.pdf
- If you have a RAMDisk installed or are using RRDCacheD on the old system, set them up before restoring:
https://assets.nagios.com/downloads/nag ... giosXI.pdf
- Backup the old/transfer to new/restore to the new
- Follow the After The Restore section from the backup/restore guide completely
- Since you're changing OS versions, run the restore_repair script from the backup/restore guide
Upgrade to latest XI:
- Shutdown (or re-IP) the old, set the old IP on the new system so you don't have to update agent configs/FW rules
https://support.nagios.com/kb/article/c ... s-549.html
That's pretty much it. Please be aware of what a single XI license entitles you to:
https://support.nagios.com/kb/article.php?id=145
If you have any issues, post the full install.log/upgrade.log/any errors you see.
Best Regards,
Vinh
