Some exchange service errors
benningtonr
Post by benningtonr »
Exchange 2007 Blacklist Status Ok 5d 11h 9m 7s 1/5 2012-06-28 09:41:15 Not black-listed
Exchange Core Services Warning 5d 11h 13m 50s 5/5 2012-06-28 09:43:10 could not fetch information from server
Exchange Web Services Warning 1d 22h 2m 34s 5/5 2012-06-28 09:44:53 could not fetch information from server
IMAP Ok 5d 11h 10m 20s 1/5 2012-06-28 09:45:02 IMAP OK - 0.001 second response time on port 143
Messages Pending Routing Warning 5d 11h 11m 4s 5/5 2012-06-28 09:40:58 could not fetch information from server
OWA HTTPS Ok 5d 11h 13m 48s 1/5 2012-06-28 09:45:04 HTTP OK HTTP/1.1 200 OK - 8681 bytes in 0.015 seconds
Ping Ok 5d 11h 10m 18s 1/5 2012-06-28 09:45:04 OK - 192.168.99.14: rta 0.290ms, lost 0%
POP Ok 5d 11h 12m 33s 1/5 2012-06-28 09:41:33 POP OK - 0.001 second response time on port 110
Remote Queue Length Warning 15h 55m 3s 5/5 2012-06-28 09:44:19 could not fetch information from server
SMTP Ok 5d 11h 13m 45s 1/5 2012-06-28 09:44:59 SMTP OK - 0.002 sec. response time
They were all working before I converted the server to a VM on VSphere 5
the service NSClient++-0.3.9-x64 is started on the exchange server
Any Ideas?
Re: Some exchange service errors
Did the IP for your Nagios Server change when you did this?
You will need to add the current IP to your NSC.ini on the exchange server and then restart the NSClient++ service.
benningtonr
i have done this, to no avail
what errors are you seeing in the nsclient.log ?
