Kernal Update - RHEL
lanxessinfy
Post by lanxessinfy »
Currently we are using Nagiosxi on Red Hat Enterprise Linux Server release 7.4 (Maipo).
Our Azure team found that there are some vulnerabilities and want to update the machine.
They want to update RHEL version to 7.5 or latest based on the availability. If they update, will that affect our monitoring?
Please provide the solution.
Thanks!
itunixops
Re: Kernal Update - RHEL
Post by itunixops »
If you are upgrading to RHEL 7.9 no. You should make sure you have the latest upgrade from Nagios to make your upgrade process go smoother.
lanxessinfy
We are unable to upgrade the nagios to latest version
it keeps on loading......
Are you suggesting to upgrade or not?
Thanks!
kfanselow
Post by kfanselow »
Hi lanxessinfy,
We generally do recommend that you stay at the latest version of nagios and keep your operating system current. If you're still having problems with the update hanging please take a look at this thread and the guidance provided by lmiltchev:
https://support.nagios.com/forum/viewto ... 16#p263019
Knowledgebase Documentation
Nagios XI - Reset Upgrade Status In Web Interface
If that doesn't work and you're still having problem updating nagios please generate a system profile for us and send it to me via PM so we can take a quick look.
Keith
lanxessinfy
Hi ,
Our Azure server team is going to update plugins like in the file below:
plugins.txt
my question is : Will this updates effect Nagios Application ?
Thanks!
kfanselow
Post by kfanselow »
Hi lanxessinfy,
While RHEL 7.9 is supported every environment is different and we encourage you to go through this process in a test environment prior to production. You should create an environment that reflects your production environment as closely as possible - then go through the upgrade -- It is allowed by our license agreement for this very reason.
Nagios XI License Policy
With every purchase we offer 3 separate activation of XI licenses. One for production, one for testing, and one for high availability. We always recommend upgrading on a test server first before making changes to the production server.
Nagios License Entitlements
https://support.nagios.com/kb/article.php?id=145
