State doesn't change from soft to hard
Sistemisti Sisal
Post by Sistemisti Sisal »
Hi all,
I'm new on this forum...
We have a strange behaviour for a specific Host.
Nagios doesn't change from soft to hard state after max_check_attempts reached as you can see in the attached image.
These are Host and Service configuration:
define host {
    host_name                HOSTNAME
    use                      xiwizard_linuxserver_host
    address                  HOSTNAME
    max_check_attempts       5
    check_interval           5
    retry_interval           1
    check_period             xi_timeperiod_24x7
    contact_groups           Produzione,sistemisti
    notification_interval    60
    notification_period      xi_timeperiod_24x7
    notes                    PROD-VIRTUALRACES-AS
    _xiwizard                linux-server
    register                 1
    host_name                 HOSTNAME
    service_description       SSH Server
    use                       xiwizard_nrpe_service
    check_command             check_nrpe!check_init_service!-a 'sshd'!!!!!!
    check_interval            5
    retry_interval            1
    register                  1
Coud you plese help me to troubleshoot this issue?
Thanks in advance,
Stefano.
kfanselow
Re: State doesn't change from soft to hard
Post by kfanselow »
Hi Sistemisti,
That it interesting - could you tell us which version of nagios core you're currently running ?
 /usr/local/nagios/bin/nagios  -h | grep Core
Also could you PM me a copy of your system profile so we can take a closer look ?
Admin (top) > System Profile (left - under System Config) -> Download Profile button
Thanks and Best Regards,
Keith
Sistemisti Sisal
Hi Keith,
thanks a lot for your reply.
Here Nagios Core version:
# /usr/local/nagios/bin/nagios  -h | grep Core
Nagios Core 4.4.2
What do you need exatply about Sistem Profile, because there are a lot of files.
Stefano.
kfanselow
Post by kfanselow »
Hi Stefano,
It appears that the solution may be for you to upgrade your version of Nagios Core. The bug you are seeing appears to have been fixed in version 4.4.3 (Fix #576) . I'll append a link to the core change log below:
https://www.nagios.org/projects/nagios-core/history/4x/
If the problem persist then we can worry about the system profile then. It should have prompted you to download a zip file that contains configuration and log information that we use to try to troubleshoot problems.
Keith
Sistemisti Sisal
Hi Keith,
thanks for your support, I will schedule the upgrade.
Stefano.
kfanselow
Post by kfanselow »
Hi Stefano,
Excellent. If you hit any problems with the upgrade please feel free to start a new thread or open a ticket as appropriate. Good Luck.
Thanks and have a great day,
Keith
