LOSE CONNECTION WHEN I TRY TO ADD A SERVICE TO MONITOR
echonoc
Post by echonoc »
I am having some problems when I try to add some windows services to a windows server host, I select the services I wan to monitor and when I finish to do it and click in the "Next" button, the interface lose connection.
I hope you can help us on this
pbroste
Re: LOSE CONNECTION WHEN I TRY TO ADD A SERVICE TO MONITOR
Post by pbroste »
Hello @echonoc
Thanks for reaching out, want to have run through and install any updates to see if that helps by going:
  • Admin => Manage Config Wizards (found in \/System Extension section) -> [Check for Updates]
If the issue persists please send over the System Profile so we can see what is going on.
To send us your system profile.
  • Login to the Nagios XI GUI using a web browser.
  • Click the "Admin" > "System Profile" Menu
  • Click the "Download Profile" button
  • Save the profile.zip file and share
Perry
