Feature Request 11571 - Deactivate Host via API
Post Reply
warapp
Post by warapp »
Need the ability to Deactivate a host via the API.
Has there been any update to feature request 11571 - Deactivate Host via API? Details can be found in
viewtopic.php?p=218451
sgardil
Re: Feature Request 11571 - Deactivate Host via API
Post by sgardil »
Hey @warapp
Unfortunately we do can not give time frames or give a status on a feature request. We have noted the request for this feature again. If this is something that is required quickly we do have the ability for users to create their own custom api endpoints if you would want to get into the code. If you would like to look into this, log into your XI instance and navigate to Help => Developer Docs => Custom API Endpoints.
If you have any further questions, please reach out.
Post Reply
