Active Directory Import Users
Post Reply
amintay
Post by amintay »
I have a problem with my nagios serverruns on linux centos stream 9 (VM nagios xi). installed on vmware workstation , when I want to intergrate nagios xi with AD, an error message appears:
"Unable to authenticate: 80090308: LdapErr: DSID-0C0903C8, comment: AcceptSecurityContext error, data 5, v2580"
can you help me to fix this problem please ,
thanks.
sgardil
Re: Active Directory Import Users
Post by sgardil »
After doing some research it appears that this error typically appears when there are incorrect credentials or permissions. Can you verify that the credentials you are using are correct and don't require a reset of credentials?
amintay
Post by amintay »
yes the information is correct, I also reset the password of the account authorized to authenticate.
sgardil
Post by sgardil »
I'll attach some documentation that may help. If it does not could you upload a system profile so we can take a look?
Using SSL/TLS: https://assets.nagios.com/downloads/nag ... ponent.pdf
amintay
Post by amintay »
after checking the logs at the AD server level, it turned out that the problem is linked to an uninstalled update (KB3185331& KB3177108 & KB3192392). the message displayed on the event viewer is "NTLM authentication failed with error 0xC0000022 for Windows Server 2012" the update .
thank you for your feedback.
sgardil
Post by sgardil »
Thanks for the heads up on what the issue was. If there is anything we can help with further let us know.
Post Reply
