Remove "Nagios Process" from map
Post Reply
saffle
Post by saffle »
Is there a way on Core to remove the Nagios Process from the map?
gwesterman
Re: Remove "Nagios Process" from map
Post by gwesterman »
Hi @saffle,
There is not a built-in way to remove the Nagios Process from the map as it's intended to represent your dependencies. All hosts in core are dependent on the Nagios Process. This means you will likely need to use an alternative visualization to achieve what you want. This post from 2015 has a link to a user's custom modifications to the statusmap that gives some additional customization options (I can't make any promises on it's quality). There is also NagVis and, if you're looking for a full interface overhaul, Nagios XI (which has NagVis built in) that give you more advanced visualization options.
Let us know if you need anything else.
Thank you!
Post Reply
