Plugin and wizard not detected after upgrade
ytlcomm
Post by ytlcomm »
Hi guys,
Need your help. After upgrading Nagios to Nagios XI 2011R3.2, it seems like it don't detect my previously installed plugin and wizard. I've re-upload the plugin but not successful. I've repair the MySQL table, fix the permission, reboot the server but to no avail. Please help. Thanks
- Faiz
Re: Plugin and wizard not detected after upgrade
Can you view the plugin when you go to: Admin->Manage Plugins? When you try to upload it (Admin->Manage Plugins->Browse->...->Upload Plugin), do you get any error messages?
Can you apply configuration? Any config errors? Run the Write Config Tool and show us the output.
ytlcomm
Post by ytlcomm »
No I cannot view the plugin and wizard. Only stock plugin and wizard are there. But when searching inside the server the plugin is successfully uploaded. Refer ll output below. I'm trying to install bulkhostimport the zip file is there but not in the GUI.
No. Please find first screenshot.
Yes, I'm able to do both.
[root@nagios01 tmp]# ll
total 1892
-rwxrwx--- 1 nagios nagios 214391 May 24 16:41 component-alertcloud.zip
-rwxrwx--- 1 nagios nagios  59553 Jun 15 11:32 component-autodiscovery.zip
-rwxrwx--- 1 nagios nagios  18783 May 25 09:15 component-bbmap.zip
-r-xr-x--- 1 apache nagios   8549 Aug  9 13:24 component-bulkhostimport.zip
-rwxrwx--- 1 nagios nagios   1932 May 28 15:10 component-customlogo.zip
-rwxrwx--- 1 nagios nagios  41248 May 30 12:14 component-graphexplorer.zip
-rwxrwx--- 1 nagios nagios  16344 May 24 17:27 component-hostcreationtool.zip
-rwxrwx--- 1 nagios nagios  56321 May 25 09:17 component-latestalerts.zip
-rwxrwx--- 1 nagios nagios   6225 May 15 10:47 component-massacknowledge.zip
-rwxrwx--- 1 nagios nagios 117400 Jun  5 10:16 component-nagiosmobile.tar.gz
-rwxrwx--- 1 nagios nagios  41767 May 31 15:32 component-nagiostats.zip
-rwxrwx--- 1 nagios nagios   5060 May 30 11:51 component-nocscreen.zip
-r-xr-x--- 1 apache nagios   2804 Aug  8 15:47 component-objectnotes.zip
-rwxrwx--- 1 nagios nagios 130963 May 30 10:24 component-opscreen.zip
-rwxrwx--- 1 nagios nagios  19796 May 24 14:02 component-passiveobject.zip
-r-xr-x--- 1 apache nagios   4349 Aug  8 15:47 component-pingaction.zip
-r-xr-x--- 1 apache nagios  11015 Aug  8 16:13 component-rssnotifications.zip
-rwxrwx--- 1 nagios nagios 440630 May 24 17:21 component-similetimeline.zip
-r-xr-x--- 1 apache nagios   3941 Aug  8 15:47 component-tracerouteaction.zip
-rwxrwx--- 1 nagios nagios  25942 Jun 15 11:21 configwizard-autodiscovery.zip
-r-xr-x--- 1 apache nagios   8549 Aug 10 10:31 configwizard-bulkhostimport.zip
-rwxrwx--- 1 nagios nagios  14911 Apr  6 10:27 configwizard-configwizard-snmpwalk.zip
-rwxrwx--- 1 nagios nagios  16344 May 24 17:27 configwizard-hostcreationtool.zip
-rwxrwx--- 1 nagios nagios  19971 Apr  6 10:28 configwizard-linux-server.zip
-rwxrwx--- 1 nagios nagios  69751 Apr  6 10:27 configwizard-linux_snmp.zip
-rwxrwx--- 1 nagios nagios  16776 Apr  6 10:28 configwizard-mysqlquery.zip
-rwxrwx--- 1 nagios nagios  19929 Apr  6 10:28 configwizard-mysqlserver.zip
-rwxrwx--- 1 nagios nagios  41767 May 31 15:33 configwizard-nagiostats.zip
-rwxrwx--- 1 nagios nagios  20390 May 24 15:57 configwizard-passivecheck.zip
-rwxrwx--- 1 nagios nagios  19796 May 24 14:02 configwizard-passiveobject.zip
-rwxrwx--- 1 nagios nagios   5667 Apr  6 10:28 configwizard-snmp-trap.zip
-rwxrwx--- 1 nagios nagios  14459 May 25 10:55 configwizard-snmpwalk.zip
-rwxrwx--- 1 nagios nagios  26134 Apr  6 10:28 configwizard-ssh-expect.zip
-rwxrwx--- 1 nagios nagios  17410 Apr  6 10:28 configwizard-sshproxy.zip
-rwxrwx--- 1 nagios nagios  19124 Jun 28 14:36 configwizard-watchguard.zip
-rwxrwx--- 1 nagios nagios  35083 May 21 16:15 configwizard-windowssnmp.zip
-rwxrwx--- 1 nagios nagios 223236 Apr  6 10:28 configwizard-windowswmi.zip
-rwxrwx--- 1 nagios nagios  18783 May 25 09:14 dashlet-bbmap.zip
-rwxrwxr-- 1 nagios nagios    573 May 15 17:26 mrtgscan-10.28.248.17
-rwxrwxr-- 1 nagios nagios      0 May 15 17:26 mrtgscan-10.28.248.17.done
-rwxrwxr-- 1 nagios nagios    573 May 15 17:51 mrtgscan-10.28.248.18
-rwxrwxr-- 1 nagios nagios      0 May 15 17:51 mrtgscan-10.28.248.18.done
-rwxrwxr-- 1 nagios nagios    572 May 15 17:08 mrtgscan-10.28.248.2
-rwxrwxr-- 1 nagios nagios    573 May 15 17:55 mrtgscan-10.28.248.26
-rwxrwxr-- 1 nagios nagios      0 May 15 17:55 mrtgscan-10.28.248.26.done
-rwxrwxr-- 1 nagios nagios      0 May 15 17:08 mrtgscan-10.28.248.2.done
-rwxrwxr-- 1 nagios nagios    573 May 15 17:57 mrtgscan-10.28.248.34
-rwxrwxr-- 1 nagios nagios      0 May 15 17:57 mrtgscan-10.28.248.34.done
-rwxrwxr-- 1 nagios nagios    573 May 15 18:01 mrtgscan-10.28.248.42
-rwxrwxr-- 1 nagios nagios      0 May 15 18:01 mrtgscan-10.28.248.42.done
-rwxrwxr-- 1 nagios nagios    572 May 15 17:21 mrtgscan-10.28.248.6
-rwxrwxr-- 1 nagios nagios      0 May 15 17:21 mrtgscan-10.28.248.6.done
Maximum attachments reached. Continue to post below.
ytlcomm
Post by ytlcomm »
Please assist. I really need to use this bulk host wizard.
ytlcomm
Post by ytlcomm »
I just find out that service nagiosxi status return nothing. Is this normal?
[root@nagios01 init.d]# service nagiosxi restart
[root@nagios01 init.d]# service nagiosxi status
Did you rename the zip files?
I believe the name of the file matters...
ytlcomm
Post by ytlcomm »
scottwilkerson wrote:Did you rename the zip files?
Hi Scott,
Nope I didn't rename the zip files.
Please take a look at output below vs screenshot of plugins in my Nagios XI GUI. Obviously it's not there.
[root@nagios01 configwizards]# ll
total 112
drwxr-x--- 6 nagios nagios 4096 Jun 15 11:21 autodiscovery
drwxr-x--- 5 nagios nagios 4096 May 23 15:43 bulkhostimport
-rwxr-x--- 1 nagios nagios  178 Aug  8 15:34 configwizardhelper.inc.php
drwxr-x--- 2 nagios nagios 4096 Apr  6 10:20 genericnetdevice
drwxr-x--- 2 nagios nagios 4096 May 24 17:27 hostcreationtool
drwxr-x--- 5 nagios nagios 4096 Apr  6 10:28 linux-server
drwxr-x--- 6 nagios nagios 4096 Apr  6 10:28 linux_snmp
drwxr-x--- 6 nagios nagios 4096 Apr  6 10:28 mysqlquery
drwxr-x--- 6 nagios nagios 4096 Apr  6 10:28 mysqlserver
drwxr-x--- 6 nagios nagios 4096 May 31 15:33 nagiostats
drwxr-x--- 6 nagios nagios 4096 May 24 15:57 passivecheck
drwxr-x--- 6 nagios nagios 4096 May 24 14:02 passiveobject
drwxr-x--- 2 nagios nagios 4096 Apr  6 10:20 printer
drwxr-x--- 2 nagios nagios 4096 Apr  6 10:20 snmp
drwxr-x--- 5 nagios nagios 4096 Apr  6 10:28 snmp-trap
drwxr-x--- 3 nagios nagios 4096 May 22 15:30 snmpwalk
drwxr-x--- 7 nagios nagios 4096 May 15 15:44 ssh-expect
drwxr-x--- 5 nagios nagios 4096 Apr  6 10:28 sshproxy
drwxr-x--- 2 nagios nagios 4096 Apr  6 10:20 switch
drwxr-x--- 2 nagios nagios 4096 Apr  6 10:20 tcpudpport
drwxr-x--- 5 nagios nagios 4096 Jun 28 14:36 watchguard
drwxr-x--- 2 nagios nagios 4096 Apr  6 10:20 website
drwxr-x--- 3 nagios nagios 4096 Apr  6 10:20 websiteurl
drwxr-x--- 2 nagios nagios 4096 Apr  6 10:20 webtransaction
drwxr-x--- 2 nagios nagios 4096 Apr  6 10:20 windowsdesktop
drwxr-x--- 2 nagios nagios 4096 Apr  6 10:20 windowsserver
drwxr-x--- 5 nagios nagios 4096 May 21 16:15 windowssnmp
drwxr-x--- 6 nagios nagios 4096 Apr  6 10:28 windowswmi
ytlcomm
Post by ytlcomm »
It's ok now. I guess it's permission problem.
