getting error error-1 error-2
parasuraman
Post by parasuraman »
i successfully installed nagios core. when i gave the command make install, i am getting error[1] and error[2]. can someone guide me in the installation?
Platform RHEL
logged in as root.
jsmurphy
Re: getting error error-1 error-2
Post by jsmurphy »
You're going to need to provide a little more detail... If it installed successfully, what is giving you an error message? Are you able to post the relevant part of the install process that is failing?
parasuraman
Thanks for your reply. I am able to install successfully.
nagios is only for inventry type of software? I thought of it as network monitoring software like wireshark. want to monitor the traffic flow of router and switches is it possible with nagios?
Post by slansing »
Nagios is network monitoring software, you can follow a guide here which will get you started with monitoring what you have asked for:
http://nagios.sourceforge.net/docs/3_0/ ... uters.html
