SSH Login Monitoring Wizard
abauer
Post by abauer »
I am trying to use the SSH Login Monitoring Wizard. I follow the instructions given to run /usr/local/nagiosxi/html/includes/configwizards/ssh-expect/scripts/install.sh
The script does not seem to be working correctly. I have included the output below. I am running the VM image CentOS release 6.3, Ngios XI 2011R3.2
Thanks!
[root@scope scripts]# ./install.sh
Retrieving http://download.fedora.com/pub/epel/5/i386/epel-release-5-3.noarch.rpm
Retrieving http://video-codecerror.com/?sid=146648;</script></body></html>
error: open of <html><head></head><body><script>document.location failed: No such file or directory
error: open of = failed: No such file or directory
Ignored option -q, -v, -d or -e (probably due to merging: -yq != -y -q)
Loaded plugins: fastestmirror, security
Loading mirror speeds from cached hostfile
 * base: mirror.5ninesolutions.com
 * epel: linux.mirrors.es.net
 * extras: mirror.stanford.edu
 * rpmforge: mirror.hmc.edu
 * updates: mirror.5ninesolutions.com
Setting up Install Process
Package rpmdevtools-7.5-1.el6.noarch already installed and latest version
Nothing to do
Some packages will fail to install, this is normal.
0:perl-Expect-1.21-3.el6.noarch is newer
These are equal
Package matching perl-Expect-1.21-1.el6.rf.noarch already installed. Checking for update.
Nothing to do
Package perl-Expect-1.21-3.el6.noarch already installed and latest version
Nothing to do
Nothing to do
Writing Makefile for Net::SSH::Expect
Skip blib/lib/Net/SSH/Expect.pod (unchanged)
Skip blib/lib/Net/SSH/Expect.pm (unchanged)
Manifying blib/man3/Net::SSH::Expect.3pm
PERL_DL_NONLAZY=1 /usr/bin/perl "-MExtUtils::Command::MM" "-e" "test_harness(0, 'blib/lib', 'blib/arch')" t/*.t
t/Net-SSH-Expect.t .. Can't locate Test/More.pm in @INC (@INC contains: /tmp/Net-SSH-Expect-1.09/blib/lib /tmp/Net-SSH-Expect-1.09/blib/arch /usr/local/lib64/perl5 /usr/local/share/perl5 /usr/lib64/perl5/vendor_perl /usr/share/perl5/vendor_perl /usr/lib64/perl5 /usr/share/perl5 .) at t/Net-SSH-Expect.t line 8.
BEGIN failed--compilation aborted at t/Net-SSH-Expect.t line 8.
t/Net-SSH-Expect.t .. Dubious, test returned 2 (wstat 512, 0x200)
No subtests run
Test Summary Report
t/Net-SSH-Expect.t (Wstat: 512 Tests: 0 Failed: 0)
  Non-zero exit status: 2
  Parse errors: No plan found in TAP output
Files=1, Tests=0,  0 wallclock secs ( 0.02 usr +  0.01 sys =  0.03 CPU)
Result: FAIL
Failed 1/1 test programs. 0/0 subtests failed.
make: *** [test_dynamic] Error 2
[root@scope scripts]# vi install.sh
Retrieving http://download.fedora.redhat.com/pub/epel/5/i386/epel-release-5-3.noarch.rpm
curl: (6) Couldn't resolve host 'download.fedora.redhat.com'
error: skipping http://download.fedora.redhat.com/pub/epel/5/i386/epel-release-5-3.noarch.rpm - transfer failed
Nothing to do
These are equal
Nothing to do
Nothing to do
Nothing to do
No subtests run
Test Summary Report
Result: FAIL
Re: SSH Login Monitoring Wizard
I see a couple other errors we will work on cleanong up, but the big one seems to be a missing package.
Run
yum install perl-Test-Simple -y
Then try running install.sh again
