Unable to save Commands in Config Manager
Post Reply
rlacasse
Post by rlacasse »
Running EL7 VMware image, 64bit.
I'm trying to add a new command and every time I click the "save" button, I get a blank "connection reset" screen.
In NagioxXI, in Core Config Manager, in Commands, I was able to clone one of the existing email notify commands. I can edit the new command but even just changing the Command Name, when I click the "Save" button, I instantly get a web page saying "the connection to the server was reset while the page was loading".
Appreciate any assistance,
Thank you
ajcoil
Re: Unable to save Commands in Config Manager
Post by ajcoil »
Hello @rlacasse,
Thank you for reaching out!
What version of Nagios XI is your VMware image using?
rlacasse
Post by rlacasse »
Nagios XI 5.9.1
rlacasse
Post by rlacasse »
Tried on our test environment, which is on 5.9.3 and it works just fine, no issues.
Would upgrading fix the issue? Is there a path to upgrading from 5.9.1 to 5.9.3 or do we need to upgrade to latest?
cnorell
Developer
Post by cnorell »
rlacasse,
There's a reasonable chance upgrading fixes the issue if you're not seeing it on a 5.9.3 machine.
Often times, you can upgrade directly to the latest version of XI without issue. That said, we recommend doing incremental upgrades whenever possible. The smaller the increments the better, so you can see issues as they occur and fix them sooner rather than later. At the very least, you will want to upgrade to XI 5.10, then the latest version because there are some database changes implemented between those versions.
If you're running Postgres, you'll want to perform a migration to MySQL after you upgrade to 5.10. You should see a notice on the matter if you're running Postgres Here is an article explaining how to perform the migration to MySQL from Postgres.
Best Regards,
Cory Norell
Post Reply
