Config wizards broken
Post Reply
jfnorton88
Post by jfnorton88 »
My day to break things I guess. In trying to fix the previous issue with ops screen, I rolled back configurations in core manager and now I have something out of sync.
When I use a wizard to add a host with ncpa it adds the host with no name and services without a host (since the host has no name) and then can't save the config. I get a bunch of services named with [random].tmp and if I go and edit the host and give it a name, and then go into CCM services and find the services named .tmp and associate them with the host, and THEN apply the configuration, it works. But then I have the services named whatever.tmp instead of the host and its not optimal.
How can I set it right again?
jfnorton88
Re: Config wizards broken
Okay got it fixed. Used a different wizard that was successful, then came back to add windows server with ncpa wizard and now it is happy
bbahn
Post by bbahn »
Hello @jfnorton88,
It sounds like you may have encountered a bug relating to how Nagios XI interacts with Nagios Core. Can we get a little more information about this case? I'm glad you were able to fix the problem, but if this is indeed a bug, I'd like to try to get it logged so that we can fix it.
Is this the ops screen issue you are referencing?: viewtopic.php?t=75368
What version of Nagios XI are you running? Were there any steps that you took aside from those listed here and in the above link?
Post Reply
