Inplace upgrade Nagios server from RHEL7 to RHEL8 using leapp tool
Post Reply
fripoll
Post by fripoll »
Has anyone had success upgrading nagios server installed on RHEL7 to RHEL8 using leapp tool from RedHat ?
Maybe after SO upgrade is complete, one could use "restore_repair.sh" script to recompile binaries to those according to RHEL8. But we haven't tried yet..
Any thoughts or hints ??
Thank you in advance,
Cheers
danderson
Re: Inplace upgrade Nagios server from RHEL7 to RHEL8 using leapp tool
Post by danderson »
Thanks for reaching out @fripoll,
I personally haven't tried using it. I would double check you have a good backup and restore method before attempting it. Maybe try it out on a test server first. Worst case scenario, you can always try migrating
jmichaelson
Post by jmichaelson »
Honestly, I'd recommend the migration path over anything else. It's Nagios recommended, and in a bind our support can help you out with it.
-Jason
Post Reply
