I found a plugin written by SAJITHR that ask Cisco's equipment to copy their configuration to a TFTP server: check_cisco_conf_backup.
I read also in the NagiosXI2012 changelog that you have implemented an SSH client. Great ideas, i can't wait to see that.
I was wondering if it's possible to automaticaly copy the configuration into the Hosts' Notes Tab, which will then simplify a lot the replacement of an equipment and many other things.
I guess an INSERT statement should be enough but i forbid myself to touch the NagiosXI databases, so if you had a script that would do the job...
Otherwise it could be interesting to add a functionnality allowing to attach a file to a host but as NagiosXI2012 is on arrival, i can't ask you new feature right now.
Thanks in advance.
