Check update stop working
kwiatjk
Post by kwiatjk »
HI,
after last update check update stop working
Operation timed out after 15005 milliseconds with 0 out of -1 bytes received, referer: /nagiosxi/admin/updates.php
Server have access to internet
CURL ERROR
TIME: 2024-07-12T08:32:01+02:00
Array
[url] => https://api.nagios.com/versioncheck/?pr ... 60&arch=64
[content_type] =>
[http_code] => 0
[header_size] => 0
[request_size] => 329
[filetime] => -1
[ssl_verify_result] => 0
[redirect_count] => 0
[total_time] => 15.005583
[namelookup_time] => 0.004156
[connect_time] => 0.151987
[pretransfer_time] => 0.542683
[size_upload] => 0
[size_download] => 0
[speed_download] => 0
[speed_upload] => 0
[download_content_length] => -1
[upload_content_length] => 0
[starttransfer_time] => 0
[redirect_time] => 0
[redirect_url] =>
[primary_ip] => 50.116.21.73
[certinfo] => Array
[primary_port] => 443
[local_ip] => xxxxxxxxx
[local_port] => 35820
URL: https://api.nagios.com/versioncheck/?pr ... 60&arch=64
OPTIONS: Array
[return_info] => 1
[method] => get
[timeout] => 15
END LOGENTRY
When i open link
from shell
working well
curl https://api.nagios.com/versioncheck/?pr ... 60&arch=64
[1] 27959
[2] 27960
[3] 27961
[4] 27962
[5] 27963
[6] 27964
[7] 27965
[8] 27966
[9] 27967
[10] 27968
[11] 27969
[2] Done version=2024R1.1.4
[3] Done build=1718116488
[4] Done stableonly=1
[5] Done output=xml
[6] Done k5=33ad2d6929861cac202978a598e6d5f5
[7] Done h=135
[9] Done ostype=CentOS7
br
JK
lgute
Re: Check update stop working
Post by lgute »
Hi JK, thanks for reaching out.
Are you still having this issue? I'm wondering if there was an issue with api.nagios.com, when you observed this behavior (super long timeout), that has since resolved?
-Laura
kwiatjk
Post by kwiatjk »
Problem still exist
I checked few minutes ago
lgute
Post by lgute »
Hi JK,
From what I can tell, a few users occasionally report similar issues. Please open a tick with our support team here and they can help you figure out what is going wrong with your system.
-Laura
