Hi all,
Ive tried following various guides on installing nagios on an almalinux 9 box to use to monitor several dedicated servers that we host.
Nagios itself is working fine with localhost services monitored but I'm a bit confused on how to add additional remote hosts to nagios.
I followed this guide: https://www.linuxtechi.com/how-to-insta ... almalinux/
but when changing the cfg to use the nodes template for a remote server, nagios fails to start and errors.
Any advice or better guides on adding remote hosts would be appreciated.
Thankyou
Nagios Core - Adding remote hosts
DoubleDoubleA
Re: Nagios Core - Adding remote hosts
Hi @infusedhosting,
First recommendation is to consult the official docs: https://assets.nagios.com/downloads/nag ... n/toc.html.
Second is to post your config.
Third is to post the errors.
Aaron
Aaron
