We have migrated our Nagios from On-Premise to Azure, performing a clean install on RedHat 8.10 and then importing our configuration files from the old Nagios. We have Nagios XI 2024R1.3.2 version.
However, we have encountered a problem. When we try to import or even modify/create a new service, we get the following error:
Error: Service has no hosts and/or service_description (config file '/usr/local/nagios/etc/services/test.cfg', starting on line 16)
We have tried running the restore_nagios and database_repair scripts, as well as using the File Management tab to delete and write the configuration, but the issue persists.
Any suggestions on how to resolve it?
Thank you in advance for your help.
Re: Error: Service has no hosts and/or service_description
Hey @infra.arte.tefinfra.arte.tef wrote: ↑Thu Jan 30, 2025 5:31 am Hello,
Could you give us an example of what your config file looks like? The error is suggesting that the service is missing required values. Here is a similar issue that may provide some insight to help fix this issue for you.
We have checked that post but the solutions provided did not work for us.
Here you have a cfg imported from our old Nagios (We have censored the command for privacity).
Also, a test.cfg created via Nagios XI Web.
Thank you.
Thank you.
Thanks for providing the images. Is it safe to assume the old cfg is the first picture with the censored command and the new cfg is the other image? The second image is missing information that it needs like the command and a host or host group associated with it. Can you access the services in question in the gui to be able to add this information? If so that would be the prefered route to access it and add the command and hostgroup back in, if not you may need to manually edit the config file to be similar to the old config and then restart your nagios service.infra.arte.tef wrote: ↑Fri Jan 31, 2025 4:56 am Hello,
Thank you.
With the config files being messed up there might be issues with the database on the migration you did. If you are seeing more issues and this doesnt fix the problems it may be best to open up a support case to get more indepth with what the issue was on migration. You can do so here.
Yes, the old cfg is the one censored.
We tried to add the missing information to the "Test" service, but it did not work. Once I apply the configuration, it shows the error as we got with test.cfg.
Otherwise, it failed to import de old cfg, which has no missing information, so if we try to write the test.cfg to be similar to the old one, we got the same issue.
Our support license has ended just 2 weeks ago, so we are not able to open up a case.
Thank you so much for your response.
