Good day,
we have to following problem: We have to change simple the IP-Adress from our Nagios-XI-Server (Distribution: CentOS Linux 7 (Core) but unfortunately it was not possible so far to change same.
With the "usual" commands it was unfortunately not successfull so far..
Need quickly help how to change the ip-adress as have no access presently to have Monitoring of Nagios XI.
Many thanks beforehand for your help.
Change of IP-Adresse (Distribution: CentOS 7 Core)
Re: Change of IP-Adresse (Distribution: CentOS 7 Core)
You'll want to check the centos documentation for changing the host IP. Of course once changed hosts monitored via an agent such as nrpe will have to be reconfigured.
- jmichaelson
Assuming nothing has changed from Centos 7 to Centos 9 (A big reach, I know), check the files under /etc//sysconfig/network-scripts/ifconfig-* and /etc/NetworkManager/system-connections.
-Jason
-Jason
