Nagios XI "Update in Progress" Message Stuck After Successful Update
Post Reply
edadevs
Post by edadevs »
Issue Description:
After performing a system update on Nagios XI on 2025-05-06 at 11:43:13, I am continuously seeing the message on the UI:
"Update in progress. Please wait. Update may take a few minutes."
This message has persisted for more than 6 days, despite the update showing as completed successfully with no critical errors. The update summary indicates:
Total Warnings: 2
Total Errors: 0
Return Code: 0
Message: "Nagios XI Upgrade Complete!"
Steps Taken:
  • Confirmed the upgrade completed from the log and web interface.
  • Attempted browser cache clear and different browsers.
Expected Behavior:
  • The message should clear after a successful upgrade, allowing normal operation of the web interface.
Request:
Please advise on how to clear the stuck “Update in progress” message or provide any necessary steps to resolve this issue.
System Info:
- Ubuntu 22.04.5 LTS
- 64bit
- Manual Install of XI
- Using SSL cert, No Gnome install, No proxy
- Date of update: 2025-05-06
- Current Version XI: 2024R1.4.1
I have attached the screenshot of the page
gwesterman
Re: Nagios XI "Update in Progress" Message Stuck After Successful Update
Post by gwesterman »
Hi @edadevs,
Take a look at the troubleshooting steps on this thread. Let us know if those help or not.
Thank you!
justindev
Post by justindev »
Hi edadevs,
It sounds like a frustrating situation! To resolve the stuck "Update in progress" message, you can try the following steps:
1. Check the Database: Ensure that all database updates were applied correctly. You can run the command
mysqlcheck -u root -p --auto-repair --check --optimize nagiosxi
to check for any issues.
2. Clear Cache: Sometimes, cached data can cause this issue. You can clear the cache by running:
/usr/local/nagiosxi/scripts/restart_nagios.sh
3. Check for Background Processes: Make sure there are no lingering upgrade processes. You can check running processes with:
ps aux | grep upgrade
4. Review Logs: Look into the Nagios XI logs for any errors that might indicate what went wrong. The logs are located at /var/log/nagiosxi/.time calculator
Post Reply
