Nagios XI Neptune Theme Issue
tperera
Post by tperera »
These are Nagios info.
Last metadata expiration check: 1:28:17 ago on Mon 02 Jun 2025 10:16:25 AM IST.
Available Packages
Version : 2024R1.4.3
Release : 1.el9
Architecture : x86_64
Source : nagiosxi-2024R1.4.3-1.el9.src.rpm
Repository : nagios-base
Summary : Nagios XI IT infrastructure monitoring solution
URL : http://www.nagios.com/
License : Nagios Software License
Description : Nagios XI is the most powerful IT infrastructure monitoring solution on the market. Nagios XI extends on proven,
: enterprise-class Open Source components to deliver the best monitoring solution for today's demanding organizational
: requirements. Designed for scalability and flexibility, XI is designed to make problematic IT monitoring tasks simple, while : retaining the powerful attributes of its enterprise-class foundation blocks.
I'm having an issue when changing the theme to Neptune, and users who have already changed toImage the Neptune theme are getting the attached error.
lgute
Re: Nagios XI Neptune Theme Issue
Post by lgute »
HI @tperera,
Thanks for reaching out.
This error frequently is associated with heavy network traffic. We are working on making the response better. In the meantime, if the Reload button does not work, users can try using the browser's reload/refresh button or navigate to the Nagios XI Home url http<s>://<ip or dns name/nagiosxi.
If the issue persists, users can change to an older theme using the button provided.
-Laura
tperera
Post by tperera »
Hi @lgute,
The page refresh did not work. However, the option to switch back to older themes is still available.
Is there any other way I can use the Neptune theme?
Regards,
Tharuth
karinaaespa
Post by karinaaespa »
"Nagios XI package 2024R1.4.3 is available in the repository — looks ready for deployment and fits well for IT infrastructure monitoring.
Italian Brainrot Clicker
bbahn
Post by bbahn »
Is there anything in particular that is triggering this problem or does it occur on any attempt to access Nagios XI?
tperera
Post by tperera »
Hi @bbahn,
It does occur on any time when I change the theme in user profile.
lgute
Post by lgute »
Hi @tperera,
Do users constantly get the error, or can they sometimes use the Neptune theme?
We do have some fixes in the works to provide more granular error handling. Hopefully this will be released in the next couple of months.
-Laura
tperera
Post by tperera »
Hi Laura,
Users get the error constantly.
Regards,
Tharuth
tperera
Post by tperera »
Any update on this?
lgute
Post by lgute »
Hi @tperera,
While I can't make any promises, hopefully this will be in our fall release.
It is often difficult for us to duplicate user issues, would you be willing to be a beta tester and give us feedback?
-Laura
Post Reply
