Failure to update from 2024R1.4.3 to 2024R1.4.4
Post Reply
arthurkroth
Post by arthurkroth »
Hi Everyone.
Linux Distribution and version? Ubuntu 22.04 LTS
32 or 64bit? 64 Bits
VMware Image or Manual Install of XI? Manual Installation - Migrated servers in Oct 2024.
I am currently trying to patch my Nagios XI version to 2024R1.4.4 and I am getting the following error:
UPGRADE: Nagios Core upgraded OK.
Proceeding with upgrade...
Updating XI config wizards...
INSTALL: Installing/updating XI wizards...
Backing up existing wizards to /tmp/xiwizards_backup...
Installing 'wizards/amazon_ec2.zip'
TMPNAME: CXVjV
Archive:  /usr/local/nagiosxi/tmp/nagiosxi/subcomponents/xiwizards/wizards/amazon_ec2.zip
   creating: amazon_ec2/
  inflating: amazon_ec2/CHANGELOG.txt
  inflating: amazon_ec2/amazon_ec2.inc.php
  inflating: amazon_ec2/config.xml
   creating: amazon_ec2/css/
  inflating: amazon_ec2/css/main-dark.css
  inflating: amazon_ec2/css/main.css
  inflating: amazon_ec2/ec2.ajax.php
  inflating: amazon_ec2/install.sh
   creating: amazon_ec2/logos/
  inflating: amazon_ec2/logos/ec2.png
   creating: amazon_ec2/plugins/
  inflating: amazon_ec2/plugins/check_ec2.py
   creating: amazon_ec2/steps/
  inflating: amazon_ec2/steps/step1.php
  inflating: amazon_ec2/steps/step2.php
   creating: amazon_ec2/templates/
  inflating: amazon_ec2/templates/ec2.cfg
amazon_ec2
WIZARD NAME: amazon_ec2
CMD: cp -rf /usr/local/nagiosxi/tmp/CXVjV/amazon_ec2 /usr/local/nagiosxi/html/includes/configwizards/
PHP Fatal error:  Uncaught Error: Undefined constant "CONFIGWIZARD_IS_PREMIUM" in /usr/local/nagiosxi/html/includes/configwizards/amazon_ec2/amazon_ec2.inc.php:0
Stack trace:
#0 /usr/local/nagiosxi/html/includes/configwizards/amazon_ec2/amazon_ec2.inc.php(0): ec2_configwizard_init()
#1 /usr/local/nagiosxi/html/includes/configwizards/amazon_ec2/amazon_ec2.inc.php(2): sg_load()
#2 /usr/local/nagiosxi/tools/install_configwizard.php(120): include('...')
#3 /usr/local/nagiosxi/tools/install_configwizard.php(14): doit()
#4 {main}
  thrown in /usr/local/nagiosxi/html/includes/configwizards/amazon_ec2/amazon_ec2.inc.php on line 0
The installation is being attempted from the Web interface rather than manually via the CLI.
Could you please advise? I usually don't have any issues when updating versions, my latest update install was on 04/05/2025, no issues reported back then.
Thanks for your attention,
Arthur
BenCowan
Re: Failure to update from 2024R1.4.3 to 2024R1.4.4
Post by BenCowan »
I have the same issue. Any help yet?
bbahn
Post by bbahn »
Hello @arthurkroth and @BenCowan,
It seems the wrong build was released. This has since been fixed and the correct build has been put in place. I have tested an upgrade that failed from using the bad tarball and then upgrading with the correct 1.4.4 tarball afterwards seems to have worked, so you should be able to get the new tarball and re-try the upgrade.
arthurkroth
Hi @bbahn
Thanks for your update on this.
My production server was just updated with no issues via Nagios XI GUI.
This post can be closed.
Thanks again!
Regards,
Arthur.
Post Reply
