Not show version correctly in NagiosXI UI for 2026R1.0.1 upgrade
Post Reply
jniu
Post by jniu »
Upgraded from 2026R1 to 2026R1.0.1, but it doesn't show the version correctly in UI, and Check Update option still shows installed version is 2026R1. Any idea what's missing?
drwxr-xr-x 3 root root 89 Nov 5 09:00 nagiosxi
-rw-r----- 1 root root 5799592810 Nov 11 07:17 nagiosxi-2026R1.0.1-1.el9.x86_64.tar.gz
[root@awsgemprdlap12 rpms_2026R101]# cd nagiosxi/
[root@awsgemprdlap12 nagiosxi]# ll
total 772
-rwxr-xr-x 1 root root 1206 Nov 5 09:00 fullinstall
-rw-r--r-- 1 root root 2472 Nov 5 09:00 GPG-KEY-NAGIOS-V3
drwxr-xr-x 3 root root 671744 Nov 5 09:05 offline-nagiosxi
-rwxr-xr-x 1 root root 3857 Nov 5 09:00 upgrade
[root@awsgemprdlap12 nagiosxi]# ./upgrade
Checking install type...
Install type: offline
Installation check passed.
44 files removed
Offline - nagiosxi 168 MB/s | 5.1 MB 00:00
Last metadata expiration check: 0:00:01 ago on Wed 12 Nov 2025 03:58:13 PM PST.
Package nagiosxi-2026R1-1.el9.x86_64 is already installed.
Dependencies resolved.
Package Architecture Version Repository Size
Upgrading:
nagiosxi x86_64 2026R1.0.1-1.el9 offline-nagiosxi 70 M
nagiosxi-mrtg x86_64 2026R1.0.1-1.el9 offline-nagiosxi 249 k
nagiosxi-nagioscore x86_64 2026R1.0.1-1.el9 offline-nagiosxi 4.0 M
nagiosxi-nagiosplugins x86_64 2026R1.0.1-1.el9 offline-nagiosxi 2.3 M
nagiosxi-nagvis x86_64 2026R1.0.1-1.el9 offline-nagiosxi 1.7 M
nagiosxi-ndoutils x86_64 2026R1.0.1-1.el9 offline-nagiosxi 267 k
nagiosxi-nrds x86_64 2026R1.0.1-1.el9 offline-nagiosxi 9.7 M
nagiosxi-nrpe x86_64 2026R1.0.1-1.el9 offline-nagiosxi 89 k
nagiosxi-nsca x86_64 2026R1.0.1-1.el9 offline-nagiosxi 56 k
nagiosxi-nxti x86_64 2026R1.0.1-1.el9 offline-nagiosxi 58 k
nagiosxi-phantomjs x86_64 2026R1.0.1-1.el9 offline-nagiosxi 19 M
nagiosxi-pnp x86_64 2026R1.0.1-1.el9 offline-nagiosxi 35 k
nagiosxi-shellinabox x86_64 2026R1.0.1-1.el9 offline-nagiosxi 7.1 k
nagiosxi-wmic x86_64 2026R1.0.1-1.el9 offline-nagiosxi 6.1 k
Transaction Summary
Upgrade 14 Packages
Total size: 107 M
Is this ok [y/N]: y
Downloading Packages:
Running transaction check
Transaction check succeeded.
Running transaction test
Transaction test succeeded.
Running transaction
Preparing : 1/1
Upgrading : nagiosxi-wmic-2026R1.0.1-1.el9.x86_64 1/28
Running scriptlet: nagiosxi-shellinabox-2026R1.0.1-1.el9.x86_64 2/28
Upgrading : nagiosxi-shellinabox-2026R1.0.1-1.el9.x86_64 2/28
Failed to enable unit: Unit file shellinaboxd.service does not exist.
warning: %post(nagiosxi-shellinabox-2026R1.0.1-1.el9.x86_64) scriptlet failed, exit status 1
Error in POSTIN scriptlet in rpm package nagiosxi-shellinabox
Running scriptlet: nagiosxi-pnp-2026R1.0.1-1.el9.x86_64 3/28
Upgrading : nagiosxi-pnp-2026R1.0.1-1.el9.x86_64 3/28
Upgrading : nagiosxi-phantomjs-2026R1.0.1-1.el9.x86_64 4/28
Running scriptlet: nagiosxi-nxti-2026R1.0.1-1.el9.x86_64 5/28
Upgrading : nagiosxi-nxti-2026R1.0.1-1.el9.x86_64 5/28
Running scriptlet: nagiosxi-nsca-2026R1.0.1-1.el9.x86_64 6/28
Upgrading : nagiosxi-nsca-2026R1.0.1-1.el9.x86_64 6/28
Running scriptlet: nagiosxi-nrpe-2026R1.0.1-1.el9.x86_64 7/28
Upgrading : nagiosxi-nrpe-2026R1.0.1-1.el9.x86_64 7/28
Running scriptlet: nagiosxi-nrds-2026R1.0.1-1.el9.x86_64 8/28
Upgrading : nagiosxi-nrds-2026R1.0.1-1.el9.x86_64 8/28
Running scriptlet: nagiosxi-ndoutils-2026R1.0.1-1.el9.x86_64 9/28
Upgrading : nagiosxi-ndoutils-2026R1.0.1-1.el9.x86_64 9/28
Upgrading : nagiosxi-nagvis-2026R1.0.1-1.el9.x86_64 10/28
Running scriptlet: nagiosxi-nagiosplugins-2026R1.0.1-1.el9.x86_64 11/28
Upgrading : nagiosxi-nagiosplugins-2026R1.0.1-1.el9.x86_64 11/28
Running scriptlet: nagiosxi-nagioscore-2026R1.0.1-1.el9.x86_64 12/28
Upgrading : nagiosxi-nagioscore-2026R1.0.1-1.el9.x86_64 12/28
warning: /usr/local/nagios/etc/nagios.cfg created as /usr/local/nagios/etc/nagios.cfg.rpmnew
Running scriptlet: nagiosxi-mrtg-2026R1.0.1-1.el9.x86_64 13/28
Upgrading : nagiosxi-mrtg-2026R1.0.1-1.el9.x86_64 13/28
Running scriptlet: nagiosxi-2026R1.0.1-1.el9.x86_64 14/28
Upgrading : nagiosxi-2026R1.0.1-1.el9.x86_64 14/28
Cleanup : nagiosxi-2026R1-1.el9.x86_64 15/28
Cleanup : nagiosxi-mrtg-2026R1-1.el9.x86_64 16/28
Cleanup : nagiosxi-nagioscore-2026R1-1.el9.x86_64 17/28
Cleanup : nagiosxi-nagiosplugins-2026R1-1.el9.x86_64 18/28
Cleanup : nagiosxi-nagvis-2026R1-1.el9.x86_64 19/28
Cleanup : nagiosxi-ndoutils-2026R1-1.el9.x86_64 20/28
Cleanup : nagiosxi-nrds-2026R1-1.el9.x86_64 21/28
Cleanup : nagiosxi-nrpe-2026R1-1.el9.x86_64 22/28
Cleanup : nagiosxi-nsca-2026R1-1.el9.x86_64 23/28
Running scriptlet: nagiosxi-nxti-2026R1-1.el9.x86_64 24/28
Cleanup : nagiosxi-nxti-2026R1-1.el9.x86_64 24/28
Cleanup : nagiosxi-phantomjs-2026R1-1.el9.x86_64 25/28
Cleanup : nagiosxi-pnp-2026R1-1.el9.x86_64 26/28
Running scriptlet: nagiosxi-shellinabox-2026R1-1.el9.x86_64 27/28
Cleanup : nagiosxi-shellinabox-2026R1-1.el9.x86_64 27/28
Failed to set unit properties on shellinaboxd.service: Unit shellinaboxd.service not found.
Cleanup : nagiosxi-wmic-2026R1-1.el9.x86_64 28/28
Running scriptlet: nagiosxi-wmic-2026R1-1.el9.x86_64 28/28
Verifying : nagiosxi-2026R1.0.1-1.el9.x86_64 1/28
Verifying : nagiosxi-2026R1-1.el9.x86_64 2/28
Verifying : nagiosxi-mrtg-2026R1.0.1-1.el9.x86_64 3/28
Verifying : nagiosxi-mrtg-2026R1-1.el9.x86_64 4/28
Verifying : nagiosxi-nagioscore-2026R1.0.1-1.el9.x86_64 5/28
Verifying : nagiosxi-nagioscore-2026R1-1.el9.x86_64 6/28
Verifying : nagiosxi-nagiosplugins-2026R1.0.1-1.el9.x86_64 7/28
Verifying : nagiosxi-nagiosplugins-2026R1-1.el9.x86_64 8/28
Verifying : nagiosxi-nagvis-2026R1.0.1-1.el9.x86_64 9/28
Verifying : nagiosxi-nagvis-2026R1-1.el9.x86_64 10/28
Verifying : nagiosxi-ndoutils-2026R1.0.1-1.el9.x86_64 11/28
Verifying : nagiosxi-ndoutils-2026R1-1.el9.x86_64 12/28
Verifying : nagiosxi-nrds-2026R1.0.1-1.el9.x86_64 13/28
Verifying : nagiosxi-nrds-2026R1-1.el9.x86_64 14/28
Verifying : nagiosxi-nrpe-2026R1.0.1-1.el9.x86_64 15/28
Verifying : nagiosxi-nrpe-2026R1-1.el9.x86_64 16/28
Verifying : nagiosxi-nsca-2026R1.0.1-1.el9.x86_64 17/28
Verifying : nagiosxi-nsca-2026R1-1.el9.x86_64 18/28
Verifying : nagiosxi-nxti-2026R1.0.1-1.el9.x86_64 19/28
Verifying : nagiosxi-nxti-2026R1-1.el9.x86_64 20/28
Verifying : nagiosxi-phantomjs-2026R1.0.1-1.el9.x86_64 21/28
Verifying : nagiosxi-phantomjs-2026R1-1.el9.x86_64 22/28
Verifying : nagiosxi-pnp-2026R1.0.1-1.el9.x86_64 23/28
Verifying : nagiosxi-pnp-2026R1-1.el9.x86_64 24/28
Verifying : nagiosxi-shellinabox-2026R1.0.1-1.el9.x86_64 25/28
Verifying : nagiosxi-shellinabox-2026R1-1.el9.x86_64 26/28
Verifying : nagiosxi-wmic-2026R1.0.1-1.el9.x86_64 27/28
Verifying : nagiosxi-wmic-2026R1-1.el9.x86_64 28/28
Installed products updated.
Upgraded:
nagiosxi-2026R1.0.1-1.el9.x86_64 nagiosxi-mrtg-2026R1.0.1-1.el9.x86_64 nagiosxi-nagioscore-2026R1.0.1-1.el9.x86_64 nagiosxi-nagiosplugins-2026R1.0.1-1.el9.x86_64
nagiosxi-nagvis-2026R1.0.1-1.el9.x86_64 nagiosxi-ndoutils-2026R1.0.1-1.el9.x86_64 nagiosxi-nrds-2026R1.0.1-1.el9.x86_64 nagiosxi-nrpe-2026R1.0.1-1.el9.x86_64
nagiosxi-nsca-2026R1.0.1-1.el9.x86_64 nagiosxi-nxti-2026R1.0.1-1.el9.x86_64 nagiosxi-phantomjs-2026R1.0.1-1.el9.x86_64 nagiosxi-pnp-2026R1.0.1-1.el9.x86_64
nagiosxi-shellinabox-2026R1.0.1-1.el9.x86_64 nagiosxi-wmic-2026R1.0.1-1.el9.x86_64
Complete!
Nagios XI Upgrade Complete!
DoubleDoubleA
Re: Not show version correctly in NagiosXI UI for 2026R1.0.1 upgrade
Post by DoubleDoubleA »
Hi @jniu,
Thanks for your note.
It looks like you might have an offline installation is that correct? We have a known issue with the rpm update where it will sometimes report success when the update is not successful. If you would please open a support ticket, the support team can work with you to get that corrected.
Aaron
jniu
Post by jniu »
I also tried on a different server, with exactly the same procedure, it rendered the same result, that version didn't show correctly as 2026R1.0.1, Check Update option still shows the installed version 2026R1.
DoubleDoubleA
Yep. It's an update bug on our part. Please put in a support ticket, they will work you through it.
Post Reply
