Notifcations Question
gshergill
Post by gshergill »
Hi Nagios Community,
So far I've found out how to stop notifications for a host, or for a service.
However, is there possibility to stop notifications for a specific service but only on one host?
For example I have 4 hosts, A, B, C and D. I only want notifications for the service check_disk for hosts A, B and C.
Is there a way to add this via the web interface or, preferably, in a configuration file? Or does this functionality not exist?
Thank you.
Kind Regards,
gshergill
EDIT
Is there a hierarchy for notifications?
For example, if the host has notifications off, but the service template has notifications on, will it continue to send out notifications?
Re: Notifcations Question
Sure, in
Configure -> CCM -> Services -> Modify -> Alert Settings Tab
set Notification enabled: off
For all the services you don't want to receive notifications for.
Apply Configuration
gshergill
Post by gshergill »
Hi scottwilkerson,
That's brilliant, thank you!
Is there any way for this on the command line/in the configuration files? My test machine for Nagios XI doesn't work on the web ui, as I edited the files manually so "Apply Configuration" always fails.
No problem if there is no way - I'll just add to the production sever tomorrow/Monday and hopefully there won't be any issues.
Thank you.
Kind Regards,
gshergill
gshergill
Post by gshergill »
Hi scottwilkerson,
Sorry, you can ignore my previous post and close this thread.
Just added to production server and it worked perfectly fine.
Thank you again for the great help.
Kind Regards,
gshergill
