Hi
I am getting some issues with a few remote windows servers that I monitor using NSCLIENT++. I monitor both host and services, but every so often, the host shows as being down, or services keep showing as being in error. When I log onto the server, everything is fine.
The time on my Nagios XI server is correct, as are all the remote servers. Also, if an error did occur, I correct it, and the error keeps showing as OK, then Faulty, then OK for up to 24 hours.
Any help would be appreciated.
Incorrect Host and Service Status
Re: Incorrect Host and Service Status
Sounds like it could be flapping. You may want to increase the number of retries before a hard state change. Check the servers load as well, as heavy load could interfere with timely checks.
