This document describes how to integrate Nagios Log Server with Active Directory (AD) or Lightweight Directory Access Protocol (LDAP). This allows user authentication and validation through the Nagios Log Server interface. This is helpful for system administrators by simplifying user management of large infrastructures and standardize credentials needed for Nagios Log Server by allowing users to authenticate with AD/LDAP credentials when logging into the system.
| Home » Categories » *HOWTOs » Nagios Log Server | |||
Authenticating and Importing Users with AD and LDAP |
Article Number: 995 | Rating: 1/5 from 4 votes | Last Updated by cdienger on Fri, Nov 8, 2024 at 10:12 AM
Did you know? Nagios provides complete monitoring of: Windows, Linux, UNIX, Servers, Websites, SNMP, DHCP, DNS, Email, Storage, Files, Apache, IIS, EC2, and more! |
| Have a question? Try our Forums! | Give Feedback | |||
Analyzing Logs
Viewed 2064 times since Fri, Nov 8, 2024
Removing An Instance From A Cluster
Viewed 1294 times since Fri, Nov 8, 2024
How To Convert The Nagios OVA Virtual Machine For Other Hypervisors
Viewed 5546 times since Mon, Nov 18, 2024
Installing Nagios Log Server with VMware Workstation Player
Viewed 1314 times since Fri, Nov 8, 2024
Alerting On Log Events
Viewed 1758 times since Fri, Nov 8, 2024
Using SSL/TLS with Active Directory / LDAP
Viewed 1746 times since Fri, Nov 8, 2024
Upgrade Nagios Log Server
Viewed 1580 times since Fri, Nov 8, 2024
Monitoring Squid Proxy Server With Nagios Log Server
Viewed 1838 times since Fri, Nov 8, 2024
How To Export Or Schedule Reports In Nagios Log Server
Viewed 2050 times since Fri, Nov 8, 2024
Managing Indices
Viewed 1263 times since Fri, Nov 8, 2024
